1994 Ford F150 Fuse link
1994 FORD F-150
269,000 MILES • V8 • 4WD • AUTOMATIC
NEW_F150_OWNER
  • 6 POSTS
My blower motor will not work in any switch position, and there is no current to it at all. The fuse under the dash checks OK. The blower motor resistor was found bad (black terminal rusted and fried), and so the resistor is now replaced... but still no power to blower. Could a fuse link have blown as a result of the fried resistor or the reverse? I have looked for a fuse link in the wires around the blower motor, but don't see any. The orange and brown motor wires disappear into the back of the squirrel-cage. I've searched for online schematics of where any fuse links might be located but nothing yet. Any help would be appreciated... Thanks!
Aug 17, 2010 at 9:58 PM
Are you getting power to the switch?
Aug 18, 2010 at 12:53 AM
NEW_F150_OWNER
  • 6 POSTS
Hi. Thanks for your reply... I'm not sure- there's power to AC condensor/clutch on the other knob but nothing to the fan/blower. Should I check contacts at back of that switch?
Aug 18, 2010 at 1:11 AM
That is where I would start. That way you will know which direction to work toward.
Aug 18, 2010 at 1:49 AM
NEW_F150_OWNER
  • 6 POSTS
Ok, checked that- there is no power to the switch either. The same two brown and black wires that power the blower motor go into the switch, along with the 2 other wires that go into resistor (yellow, green, brown and black all go into resistor). Where does the system connect to common?
Aug 18, 2010 at 8:33 AM
The ground is a black wire behind the left cowl panel
Aug 18, 2010 at 10:13 PM
NEW_F150_OWNER
  • 6 POSTS
Ok, found that, and the blower fuse in the fuse box is ok, so the open line must be on the other side of the system. Can fuseable links be anywhere in that blower wiring harness? Like I said, the resistor had a burned-out terminal, so I'm suspecting there's a fuseable link that is also burned open... is there a standard location for those? Thank you.
Aug 19, 2010 at 8:23 AM
There isn't a fuseable link for this component. It is fused. As far as the burnt wire and resister, that can be caused by a blower motor that is drawing too many amps. It isn't uncommon.
As far as the problem, you must have a damaged power wire to the switch. Have you checked them for continunity?
Aug 19, 2010 at 9:36 PM
NEW_F150_OWNER
  • 6 POSTS
OK, thanks, that may have solved the problem. That made me get better at using the volt meter- there is power to the fuse box, then power at the motor, but none to the switch, yet the switch shows ground... so it looks to me like the motor itself is bad. I've ordered a new one and we'll see if thats the problem. Thanks!
Aug 20, 2010 at 1:32 PM
Let me know how you make out with this.
Aug 20, 2010 at 10:59 PM
NEW_F150_OWNER
  • 6 POSTS
Yes, that was it. The motor had blown as well. New one is working now. Thanks for your help!
Aug 21, 2010 at 2:56 PM
Great! I'm glad it's fixed. Let us know if you have questions in the future, and thanks for using 2carpros.com.
Aug 21, 2010 at 9:38 PM
