1994 Ford F150 CLUTCH PEDAL
1994 FORD F-150
189,000 MILES • 6 CYL • 2WD • MANUAL
RAMAL JACKSON
THE PUSH ROD CONNECTED TO MY CLUTCH PEDAL BROKE. SO I CHANGED THE WHOLE UNIT AND NOW MT CLUTCH PEDAL WONT COME BACK UP. HOW DO I FIX THIS PROBLEM?
Feb 16, 2010 at 8:52 AM
EMKAY4597
[quote:268193e824="RAMAL JACKSON"]Transmission problem
1994 Ford F150 6 cyl Two Wheel Drive Manual 189000 miles
THE PUSH ROD CONNECTED TO MY CLUTCH PEDAL BROKE. SO I CHANGED THE WHOLE UNIT AND NOW MT CLUTCH PEDAL WONT COME BACK UP. HOW DO I FIX THIS PROBLEM?[/quote:268193e824]
it sounds like you need to bleed the system.
even if you have they are a pain. try it again and see if it helps.
Apr 19, 2010 at 2:08 AM
