1993 Ford F150 WON'T RUN
1993 FORD F-150
14,300 MILES • 6 CYL • 2WD • AUTOMATIC
SANDWEDGE
I CAN START THE TRUCK WITH A CAN OF STARTING FLUID, BUT WHEN IT RUNS OUT THE TRUCK STOPS. I MADE SURE THERE IS NEW CLEAN GAS IN THE TANK AND TOOK OFF THE AIR FILTER BOX SO THERE IS NO OBSTRUCTION. WHAT DO YOU THINK IT MIGHT BE.
Jun 10, 2008 at 8:17 PM
Check the inertia fuel cutoff switch if its tripped if not check fuel pump fuse and relay-
Jun 11, 2008 at 2:48 AM
SANDWEDGE
The inertia switch was not tripped so I popped it up and reset it. The fuel pump fuse and relay are fine. I also replaced the fuel filter and it was full of fuel and came out both sides. The truck will start and run for a few seconds with starter fluid still but then cut off.
Jul 12, 2008 at 1:25 PM
Check the fuel pressure if its within specification and also for injection pulses-
Jul 12, 2008 at 3:28 PM
SANDWEDGE
whats the best way to do that?
Jul 17, 2008 at 4:54 PM
You need a fuel pressure gauge designed for your fuel system and tap into the fuel test port and also a noid light to check for injection pulses at the injector/s wire connector
Jul 17, 2008 at 5:20 PM
