1993 Ford F150 Pushrod cover gasket on an inline 6
1993 FORD F-150
158,900 MILES • 6 CYL • 2WD • AUTOMATIC
HUKEEDO
I have a 93 F150 2wd with a 6 cyl inline 300. I was told the push rod cover gasket is leaking and i want to know how difficult is is to change that. Do I have to remove the Distributor? What are the steps to doing the job?
Mar 22, 2009 at 8:35 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3c28a0f7e4="Hukeedo"]Engine Mechanical problem
1993 Ford F150 6 cyl Two Wheel Drive Automatic 158900 miles
I have a 93 F150 2wd with a 6 cyl inline 300. I was told the push rod cover gasket is leaking and i want to know how difficult is is to change that. Do I have to remove the Distributor? What are the steps to doing the job?[/quote:3c28a0f7e4]
No you don't have to remove the distributor. It is not that dificult to do. All you have to do is remove the bolts from around the cover. There may be some wires and hoses that just need to be pulled out of the way a little. You may even have to disconnect some of the wires and or hoses.
Mar 22, 2009 at 8:55 PM
