1993 Ford F150 engiine runs hot
1993 FORD F-150
100,000 MILES • V8 • 2WD • AUTOMATIC
PAULCATS
  • 7 POSTS
I relpace thermastat,radiator, runs hot, then goes back to half way, then runs hot again, thanks
Apr 9, 2009 at 9:29 PM
2CARPRO JACK
  • 11,533 POSTS
When the gauge goes full hot does th eengine actually overheat? it should push coolant out or make a deep popping sound when overheating.If not it may be a bad gauge/sender or connection in between. May want to try a manual temp gauge also to monitor it before attempting to diagnose an electrical or overheating issue
Apr 10, 2009 at 4:58 PM
PAULCATS
  • 7 POSTS
Thanks for answer, when trucks gauge gets hot, the engine is not really hot, water sending unit was replaced, engine is hot , but not real hot like gauge says. don"t know if gauge is bad or not, thanks
Apr 10, 2009 at 11:27 PM
2CARPRO JACK
  • 11,533 POSTS
Try an aftermarket to be sure of where it is really running
Apr 11, 2009 at 7:32 AM
PAULCATS
  • 7 POSTS
Jack thanks, could a clog catalactic converter cause a engine or gauge to run hot? thanks, ps I "ll try to send you or who ever a donation, thanks
Apr 11, 2009 at 11:08 PM
2CARPRO JACK
  • 11,533 POSTS
It could, but it would most likely just go hot and stay that way until the engine cooled down, not go back and forth like you described
Apr 12, 2009 at 7:45 AM
PAULCATS
  • 7 POSTS
Jack, thanks, I"ll try new gauge, get backto later, could there be a flowing problem somewhere else, or could thermastat still be causing problems, thanks
Apr 13, 2009 at 7:44 PM
2CARPRO JACK
  • 11,533 POSTS
Flow problems usually cool off when you start driving them , but get hot at idle, they rarely spike up and down.You could try another t-stat, I have gotten bad ones before, but not too often
Apr 14, 2009 at 7:43 AM
PAULCATS
  • 7 POSTS
Jack hi, This is Paul, Hay change top @ bottom hoses, both were colulapsing when engine runs hirer, so I change them, did not help, so after changing them @ driving it did the same, got home check under hood, top hose hot, check bottom it was cool after driving for awhile, It "s got me, Hay thanks//////////////
Apr 17, 2009 at 10:52 AM
2CARPRO JACK
  • 11,533 POSTS
Have you tried a manual gauge to see what the temp actually is? Also have it chemical tested for a blown head gasket
Apr 20, 2009 at 12:18 PM
PAULCATS
  • 7 POSTS
Hello jack, i hope I got your name correct, used a manual guage , still runs hot, so I think a worn out water pump, or a blown head gasket, bought a chemical kit for checking head gaskets, haven"t check yet, I think water pump is bad, yet you know, thanks
Apr 20, 2009 at 9:12 PM
PAULCATS
  • 7 POSTS
Hello, We tried mechanical gauge, cylinder leakage test, no leaks, but found a big air pocket @ after that it seems fine. thanks
Apr 29, 2009 at 10:07 PM
