1992 Ford F150 starts and idles ok, release gas pedal and i
1992 FORD F-150
AG_DORION
Engine Mechanical problem
1992 Ford F150 V8 Two Wheel Drive Automatic
you get in, start the truck and everything is ok, it runs a little rough though. once you use the gas pedal its still ok, but one you release it the engine will not return to idle, its revs go down until it stalls. Ive checked and its not the torque converter
Feb 23, 2010 at 2:48 AM
Do you have a check engine light and when was your last tuneup??
Clean out the idle air control valve and EGR/PCV valves and test the TPS and MAF sensor
Feb 23, 2010 at 3:33 AM
