1992 Ford F150 replace freeze plug in engine block
1992 FORD F-150
NIK_4MAN
Engine Cooling problem
1992 Ford F150 6 cyl Two Wheel Drive Automatic
how many? and what do we have to do?
Dec 19, 2008 at 4:18 PM
BLACKOP555
  • 10,386 POSTS
theres 10 of them and you wont get to all of them with the engine in the vehicle..
to remove them hit one corner of them with a punch to turn it sideways in the block, then pull it out with lpliers, make sure you drain the block or coolant will pour out..
or if you have a slide hammer and a sheet metal tip you can drill a hole in them, thread the hammer in and pop them out.
to put them in use a core plug installer tool or a socket that is smaller then the plug.
Dec 20, 2008 at 12:24 PM
