1992 Ford F150 power steering pump
1992 FORD F-150
163,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYREDROBBIN
My truck makes a chirpin grinding type noise coming from the power steering pump also leaking power steering fluid , is the pump the problem Please help
Oct 25, 2008 at 3:55 PM
BMRFIXIT
  • 19,053 POSTS
1ST you should locate the leak
if fluid Level low the pump will be noisy add fluid and check for leak
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 25, 2008 at 5:20 PM
