Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Brakes
Parking Brake
Pedal
Replace/Remove
1992 Ford F150 Parking brake pedal assembly removal
1992 FORD F-150
145,000 MILES • V8 • 4WD • MANUAL
RON DONALDSON
MEMBER
1 POST
FOLLOW
How do I remove the parking brake pedal assembly, ie. disconnect the cable from the assembly?
Aug 27, 2010 at 6:48 PM
CERTIFIED EXPERT
The tension needs removed from the cables. Then at the end of the cable, it will have a lead ball that you will slide forward and out of the catch.
Aug 28, 2010 at 12:37 AM
