Thanks for addvce regard selenod, yes it was the ground to the truck body. Thanks
Question - how do you chsnge out the started clutch switch. There is a rod that goes thriugh a switch, but the reolacement part ( ford pt # 5993) is only the switch. How do disconnect the rod etc from the truck body inorder to install the new switch. Thanks
Sep 7, 2010 at 8:27 PM
