1991 Ford F150 voltmeter not working
1991 FORD F-150
260,000 MILES • 6 CYL • 4WD • MANUAL
KONABILL
i've tested the electrical system and the battery reads 12.5- to 12.6 volts with the ignition off and 14.4 or more with the truck running, but the voltmeter on the dash stays pegged to the left with the engine running but the battery is not discharging. anyone have any suggestions or do i have to pull the instrument cluster to check the gauge itself,
thanks for any idfas. bill
Jul 13, 2010 at 7:31 PM
From the checks, everything sounds like it is working correctly. Therefore, you either have a bad gauge itself or there is a broken or loose wires. Check under the dash and also, make sure the fuseable links from the alternator are in good condition. Check all of them for continunity.
Jul 16, 2010 at 9:29 PM
