1991 Ford F150 Truck quits running
1991 FORD F-150
240,000 MILES • 4 CYL • 2WD • MANUAL
ANGEL_GIRL
  • 8 POSTS
truck runs good while setting and idling or driving at a low speed; but as soon as pull out onto highway it sputters and quits running after letting it set for a while it will start back. I used a code reader on it and it reads that egr valve not opening egr sensor I replaced egr sensor and cylanoid and fuel pump relay switches and ecc relay. plz help I'm at my witts end.
Mar 18, 2008 at 6:44 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like a weak fuel pump. you need to install a manual gauge to see the fuel pressure.
Mar 18, 2008 at 6:45 PM
