Heater problem
1991 Ford F150 6 cyl Two Wheel Drive Automatic 130K miles
Hi, replaced heater hoses, blew out heater core (appears no obstruction). Water pump is new 6 months ago, as is thermostat and housing. 4.9L, E40D transmission. When engine reaches operating temp, the hose to the thermostat is hot, hose to the pump is cold! Again the core looks brand new and was easy to blow fluid by mouth through it. Still no luck with heat. The temp lever in cab has very little affect in bringing warmer air.
Hmm,
Thank you
Hmm,
Thank you
Dec 18, 2008 at 2:11 PM
