1991 Ford F150
1991 FORD F-150
ACH
Have replaced clutch, pressure plate, throwout bearing, and slave cylinder, when reassembled truck is still making noise and transmission does want to engage.
Nov 9, 2007 at 1:29 PM
IMNOTLOKIN
  • 11 POSTS
HI, here is something I found the hard way. Did all the same things you did, and no luck. Do you have the plastic slave piston that pushes the clutch? Mine was and I had someone push the pedal in and the piston barely moved. I had a big plastic "C" that kept the piston on the fork of the tranny. Below is a better idea. I moved the piston closer.
www.novak-adapt.com/.../hcr_slides/top_view.jpg
Hope this helps.
Nov 15, 2007 at 12:12 AM
