1990 Ford F150 truck runs bad after replacing fuel pump
1990 FORD F-150
223,348 MILES • 6 CYL • 2WD • MANUAL
MIKEREARDON
Hello after I repaced the front fuel pump and fuel filter the trucks doesnt run right such as trying to gain speed it sputters and misses until i get above 2000 rpms? I even replace all plugs and plug wires and rotory button and cap what else could make it do this check engine light does not come on either please respond.
Apr 3, 2008 at 7:04 PM
BLACKOP555
  • 10,386 POSTS
first make sure the pump is hooked up correctly and none of the fuel lines are kinked or disconnected
ALso check to see if the fuel filter is installed the proper way, make sure it isnt hooked up backwards.
Apr 8, 2008 at 5:24 PM
