When you turn the key on the fuel pump stays running, no matter which tank you switch on and the truck turns over fine but will not crank up. And right before it quit runnung completely, It had a very high idle. Have replaced the tank selector switch, fuel pressure regulator,fuel pump relay, ignition module, idle air module and key switch in steering column. What else could be the problem? Is this one of the signs when the ecm is bad?
Sep 11, 2008 at 4:36 PM
