1990 Ford F150 fuel pump?
1990 FORD F-150
225,000 MILES • 6 CYL • 2WD • MANUAL
PUDUOMO
It won't start. It has two tanks but I only use the rear due to leak in middle tank. I can smell gasoline when I try to start it. I know there is a reset button for fule pump....but where i don;t know. It runs great when it runs. Is this a fuel pump issue? where is the fuel pump? Do both tanks have a fuel pump?9.00
Oct 8, 2008 at 3:46 PM
RACEFAN966
  • 5,029 POSTS
Ok it is an inertia switch and it is inside the cab. On the inside firewall it will be between the ebrake pedal and clutch pedal. It has a red button on the top just push it if it is bad. You said you smell fuel this usually means you have fuel. You should check and make sure you have spark. Hope this helps.
Oct 8, 2008 at 7:12 PM
