1990 f150
1990 FORD F-150
DCANGELSFAN
I have a 1990 f150 v8 302 with 260,000 miles. the trany coolant line busted and everything got wet with coolant.after replacing it it wouldnt start only crank. so i dried the distributor out. then it started but sputters like its still wet. so i replaced the plugs, wires,cap, and rotor i still have the same problem. it fires but sputters real bad
May 28, 2007 at 2:15 PM
BLACKOP555
  • 10,386 POSTS
you will have to dry off all sensors and connectors.
any important sensors get wet? if so they could have been ruined adn require testing.
did the ignition module get wet? the coil?
Nov 30, 2008 at 8:36 AM
