1989 Ford F150 R&R fuel pressure regulator on fuel inje
1989 FORD F-150
120,000 MILES • 6 CYL • 2WD • MANUAL
DIETERSCHMIED
  • 8 POSTS
My engine started idling rough then it regressed to hardly idling at all. The exhaust showed a rich mixture. I check vacuum lines and I remove the other end of the line going to the fuel pressure regulator and found gasoline slowly coming out of the vacuum line where it was attached to the intake manifold. Apparently the diaphragm in the regulator ruptured.
I can see the regulator below the manifold casting and I can get the visible vacuum line off, but how does one get to the regulator in order to remove it without removing the manifold? Is it possible?
Apr 27, 2010 at 9:37 PM
BLACKOP555
  • 10,386 POSTS
take the manifold off and save yourself the trouble. ive done them with it on before. took way too much time and hassle. take off the manifold regulator will come right off. only other thing you could try is pop off the fuel lines and pop the fuel rail off the injectors then replace it and put the line back on but once again thats too much trouble when taking the intake manifold off is easy and fast.
Apr 28, 2010 at 12:22 PM
