What is the trick to removing the covers on the upper steering column to access the internal ign switch components. When I turn the key the dash lights usually come on and then the starter does not engage when the key is rotated to the start position. The vehicle will start if the solenoid is jumped so I believe the problem is in the column. Can you help me out? I replaced the switch on the lower column and I still have no voltage at the solenoid from the switch. If I jump 12v to the small top terminal on the solenoid the starter spins so I suspect a problem between the ignition switch and the solenoid. I don't have a great deal of experience with Fords so I dont know the circuitry well enough to wing it without a wiring diagram. I hate to buy a book for this one repair. I'm trying to help out someone else. Any helpful tips you could throw my way would be appreciated.
Aug 27, 2010 at 5:28 PM
