1988 Ford F150 fuel pump
1988 FORD F-150
SWEETTHING
Engine Mechanical problem
1988 Ford F150 6 cyl Four Wheel Drive Manual
while driving speed started dropping truck would not accelerate then went dead. How do I check to see if fuel pump is working. and is there any reason why a test light would show no power going to the pump on the frame.
May 25, 2008 at 12:49 AM
You need a fuel pressure gauge to check fuel pressure-no power to fuel pump could be a fuse/fuel pump relay/inertia switch problem.
May 25, 2008 at 5:48 AM
