Engine Performance problem
1988 Ford F150 V8 Two Wheel Drive Automatic
5.0 302
The ford is stalling, black smoke on start up. Rough idle and dies at stop signs and in driveway.
I got a code reader and the above codes are displayed.
What is a ECT? and it's out of range? So is cooling temp sensor. Where on the engine is the cooling temp sensor? (error code 21)
ECT sensor is out of range/circuit open. Where is the ECT on the engine? (error code 51)
Fuel pump circuit failure. Where is the fuel pump circuit located? (error code 87)
EGR Control circuit fault. EVAP control system fault/voltage higher than closed limit. Defective EDT pressure transducer sensor. (error code 34). Where/what is/are the EVAP control on motor? And can any of these parts be cleaned instead of purchasing new?
5.0 302
Nov 5, 2009 at 9:52 PM
