Transmission problem
1987 Ford F150 6 cyl Four Wheel Drive Automatic unknow miles
my new to me f150 4x4 with a auto trans C6 i think.
when the truck has sat over night. when i start it up i can put it into reverse trans will go into reverse no lag in time but when i go into drive it will take up to 3-5 seconds at a idle before you can feel it go in to drive. after it warms up not as bad. the trans fluid is filthy more brownish color than red. a friend said my problem is because the filter are clogged up and it takes time for it to be sucked back uo into valve body. some times he is full of BS and not sure i can believe him or not. sound right to you ??? oh one more thing if i put my foot into the gas hard trans wont shift till i let off the gas. drive normal it's shifts like it should shifts are firm not sluggish at all could that be cause of no vacuum or bad modulator ??
Oct 29, 2008 at 2:16 PM
