Transmission problem
1987 Ford F150 Two Wheel Drive Manual 112352 miles
Hello, I have a 87 Ford F150 with a 4.9L , straight 6 engine with a manual transmission. The other day the shift stick broke off even with the ball where it mounts into the transmission. I was able to remove the ball and key (?) segment from the transmission. I have a new stick and I am trying to install it. I can get it back into the transmission, but it won’t shift. When I look inside the transmission I see the slot it fits in (I think) and there is a pin at the bottom. Does the key rest on top of this pin? Or do I have to push this pin back to one side to seat the new stick? The pin seems to be spring loaded. If so, how do I do this?
I would appreciate any information you may have to help me get this fixed. Thank you in advance for any type of help you can give me.
Thank you, Bernard Nuber
[email protected]
[email protected]
Dec 6, 2007 at 11:58 AM
