1987 Ford F150 clutch
1987 FORD F-150
HCA1
Transmission problem
1987 Ford F150 6 cyl Two Wheel Drive Manual a lot miles
hard to get in gear hard to shift its like you cant push clutch pedal in far enough. doesnt slip,fluid full,tried putting a little shim between push rod and lever on trans didnt help
Mar 7, 2009 at 8:07 PM
MIKE H R
  • 3,094 POSTS
sounds like the throwout bearing is going. It is not pushing the fingers on the clutch plate far enough to release the clutch plate. there could also be the problem of the clutch plate iself.
Mar 8, 2009 at 9:53 AM
