1987 Ford F150 axle removal
1987 FORD F-150
LANGSTON08
  • 4 POSTS
1987 Ford F150 V8 Four Wheel Drive Automatic
how do i remove front driver axle on a 1987 ford f-150 4x4?
Oct 18, 2008 at 3:07 PM
AUTOFIXER2
  • 29 POSTS
It depends which axle setup you have. these are the options:
dana 44IFS, dana 44IFS-hd, dana 50IFS
remove the calipers and the hub/rotor assemblies. remove the nuts holding the spindle to the steering knuckle. tap the spindle with a plastic mallet to remove it from the knuckle. remove the splash shield. on the left pull the shaft from the carrier through the knuckle. on the right remove and discard the clamp from shaft & joint assembly and stub shaft. slide the rubber boot onto the shaft & pull the shaft & joint assembly from the splines of the stub shaft. place the spindle in a vise on the second step of the spindle. use a slide hammer and bearing puller to remove the bearing.
Oct 18, 2008 at 5:43 PM
AUTOFIXER2
  • 29 POSTS
the other option is the dana 60 monobeam.
remove caliper. remove free running hub. remove front wheel bearing. remove hub/rotor assembly. remove spindle to knuckle bolts and tap the spindle out. remove splash shield and caliper support. pull the axle shaft out through the knuckle. using a slide hammer and bearing cup puller, remove the needle bearing from the spindle. clean and inspect the spindle bore thoroughly. good luck!!!
Oct 18, 2008 at 5:50 PM
LANGSTON08
  • 4 POSTS
not sure exactly which dana it is its the factory one for 1987 ford f-150 what happened was the yoke broke and we cant get the longer part of the axle to pull out any suggestions on what we can use to pull it out? it says june 87
AUTOFIXER2
  • 29 POSTS
i don't know what you have there, obviously. if you've followed the directions all the way through, then try prying the shaft out with a pry bar.
Oct 18, 2008 at 5:56 PM
LANGSTON08
  • 4 POSTS
i have even went ot the extent of placing a cahin around it and pulling with another truck and still will not move. prybars "broke 2" and i guess ill have to rent a slide hammer. as for the diff im not sure what it is but do know that the front cover is part of the housing or CVU guards what ever you want to call it. i called a guy and he said there was a C-clip or something holding it but when i removed the one im putting in the truck now from the junk yard it just pulled right out?
Oct 18, 2008 at 6:12 PM
AUTOFIXER2
  • 29 POSTS
the picture i have shows a c-clip on the right hand axle at the transfer case. i can't tell if it's inside or outside the case. if there's a c-clip you'll never get it out. if you don't see a clip outside it must be inside, like a rear diff. let me know
Oct 18, 2008 at 8:35 PM
LANGSTON08
  • 4 POSTS
ok dana 44 ttb we found on it any thing u can find on that?
Oct 18, 2008 at 9:07 PM
AUTOFIXER2
  • 29 POSTS
check out this link. let us know how you do.
http://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Oct 18, 2008 at 9:27 PM
LANGSTON08
  • 4 POSTS
thanks alot i found the diagram right before u sent the link and now we know how to remove it thanks alot for your help
Oct 18, 2008 at 10:01 PM
AUTOFIXER2
  • 29 POSTS
would you mind clueing us in? thanks.
Oct 18, 2008 at 10:24 PM
