It depends which axle setup you have. these are the options:
dana 44IFS, dana 44IFS-hd, dana 50IFS
remove the calipers and the hub/rotor assemblies. remove the nuts holding the spindle to the steering knuckle. tap the spindle with a plastic mallet to remove it from the knuckle. remove the splash shield. on the left pull the shaft from the carrier through the knuckle. on the right remove and discard the clamp from shaft & joint assembly and stub shaft. slide the rubber boot onto the shaft & pull the shaft & joint assembly from the splines of the stub shaft. place the spindle in a vise on the second step of the spindle. use a slide hammer and bearing puller to remove the bearing.
Oct 18, 2008 at 5:43 PM
