Electrical problem
1985 Ford F150 6 cyl Two Wheel Drive Manual 109*** miles
So I bought this old f150 as a restoration project. Thed only problem i had up until a week ago was an axel seal that i replaced myself and the brakes. So i proceeded to put in a sound system. I bought a new head unit and installed it with ease. I went to install the amp. I put it in, it sounded great. i drove about 3 miles and the amp (and subs because they were hooked up through the amp of course) shut off. The amp is fairly new and has no issues. I've checked all of the connecions and they're fine. Battery wire hooked straight to the posi side of the battery, ground hooked to the bottom of the chair assembly which connects to the frame, and the remote wire is run straight from the amp to the fuse box. I can't understand why it shut off, can you help?
Jul 18, 2010 at 10:32 PM
