1984 Ford F150 NON SHIFT
1984 FORD F-150
79,000 MILES • V8 • 2WD • AUTOMATIC
FINDANSWERNOW
THIS TRANSMISSION WAS 2QTS OVERFILLED, SO I CHANGED FILTER AND REFILLED TO PROPER LEVEL, NOW I HAVE TO GET IT UP TO 40MPH TO CHANGE TO 2ND AND 55MPH TO CHANGE TO 3RD, I CANT FIND NO VACCUM MODULATOR AS SOMEONE TOLD ME.THANKS FOR ANY HELP.
Mar 5, 2008 at 9:28 PM
2CARPRO JACK
  • 11,533 POSTS
Does it have a rod from the throttle to the trans? If so the valve inside may be stuck or the rod needs adjusting. How did it get overfilled in the first place? was work being done on it? what for? same problem?
Mar 6, 2008 at 7:39 AM
FINDANSWERNOW
[quote:4f53c1d969="2CarPro Jack"]Does it have a rod from the throttle to the trans? If so the valve inside may be stuck or the rod needs adjusting. How did it get overfilled in the first place? was work being done on it? what for? same problem?[/quote:4f53c1d969] yes it has a throttle rod to the trans, my uncle loaned it to an elder gentleman and he overfiled it,autozone says there is a modulator but i cant see a vaccum line,i also was thinking about adjusting the rod which direction would you suggest more rod or less,
Mar 6, 2008 at 6:57 PM
2CARPRO JACK
  • 11,533 POSTS
Try less. There probably isnt a vacuum mod if it has a throttle valve. Did you look on the pass side of the trans?
Mar 7, 2008 at 7:11 AM
FINDANSWERNOW
[quote:4936e7a9b9="2CarPro Jack"]Try less. There probably isnt a vacuum mod if it has a throttle valve. Did you look on the pass side of the trans?[/quote:4936e7a9b9] thks for your help you sent me in the rite direction the rod at the carb to the trans had come off at the carburtor i put that on and i back in business tks again
Mar 8, 2008 at 6:30 PM
MASTERTECHTIM
  • 4,750 POSTS
that jack guy really knows his stuff.
Mar 8, 2008 at 6:31 PM
FINDANSWERNOW
[quote:fa67037afa="FINDANSWERNOW"][quote:fa67037afa="2CarPro Jack"]Try less. There probably isnt a vacuum mod if it has a throttle valve. Did you look on the pass side of the trans?[/quote:fa67037afa] thks for your help you sent me in the rite direction the rod at the carb to the trans had come off at the carburtor i put that on and i back in business tks again[/quote:fa67037afa] ps. i tried to give you some good feed back but with me having only .2 points it wouldnt let me
Mar 8, 2008 at 6:47 PM
