Transmission problem
1982 Ford F150 V8 Four Wheel Drive Automatic 389tho miles
gday i have just had a C6 trans overhauled and fitted it into ford f150 1982,i put brand new trans hose to a brand new trans cooler and a dacco 2500 converter.i have drove it for 1 week and then it started to make a noise like low power steering sound that got a higher pitch at higher revs? i got home and took the lines off and started it on stands,went through the gears and nothing came out? obviously not pumping fluid it hasnt even pumped fluid into the new trans cooler for the whole week i have driven it?although haveng a nice hard shift into each gear all week and stalling to 2500 and all running just as it should you would never have known it wasnt pumping through the cooler until it made the noise? my question is ,how can the trans run beitiful for a week not pumping fluid through the lines to the cooler and what would create the pump to not pump when the converter is correctly installed and lined up?
Apr 7, 2008 at 10:42 AM
