1980 Ford F150 Battery vs. Altenator
1980 FORD F-150
128,000 MILES • V8 • 4WD • AUTOMATIC
VULCANK1
How can I know if I have a bad battery, or if I need to change out the new one wire altenator I just put in my truck? It checks out with a ohms meter as shown in the diagrams I saw prior to registering. The battery is approximately 2 years old.
Jan 3, 2008 at 4:20 PM
BMRFIXIT
  • 19,053 POSTS
[quote:45b5c4c2fe="VulcanK1"]Electrical problem
1980 Ford F150 V8 Four Wheel Drive Automatic 128000 miles
How can I know if I have a bad battery, or if I need to change out the new one wire altenator I just put in my truck? It checks out with a ohms meter as shown in the diagrams I saw prior to registering. The battery is approximately 2 years old.[/quote:45b5c4c2fe]
What you need is a volt meter to
test volts when truck running.
if about 14.5 alternator is OK and its the battery
if you need a jump to start and run fine and OK after that
battery no good
also you have a voltage regulator in this truck its wise to replace it first if battery OK
Jan 3, 2008 at 4:44 PM
