1979 Ford F150 Howling noise in trans area
1979 FORD F-150
125,000 MILES • V8 • 2WD • AUTOMATIC
DRUNGE
  • 19 POSTS
1979 F-150, when I hit 38 mph, there is a hum/howling noise from the middle or rear end of the truck. Gets louder as I increase speed. It stops completely when I let off the accelerator or shift into neutral.
Nov 28, 2009 at 4:16 PM
Have you checked the rear differential fluid? Make sure it is full and clean. Also, check for play at the pinion bearing and check u-joints.
Let me know what you find.
Dec 4, 2009 at 8:14 AM
DRUNGE
  • 19 POSTS
fluids are all okay. Just did the initial start-up after the engine swap. Tranny was great when it was parked last Friday, before we tore into the engine.
Jun 23, 2012 at 10:42 PM
