1978 Ford F150 Changing waterpump
1978 FORD F-150
200,000 MILES • V8 • 4WD • AUTOMATIC
EJLOTT
I am changing the water pump and i need to know how to remove the fan and pully off the water pump shaft
Mar 26, 2010 at 9:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
not sure what motor you're working on but should just remove shroud out of way, remove radiator for clearance, remove the 4 fan clutch-to-water pump hub bolts and lift off the fan/clutch assembly. remove the 4 fan-to-clutch bolts and separate fan from clutch. if its on diesel motor then i believe you need a couple of specialty tools for the job.
Mar 26, 2010 at 11:46 PM
