1977 Ford F150 Starter Relay wiring
1977 FORD F-150
359,000 MILES • V8 • 2WD • AUTOMATIC
SCIGUY
I need a diagram or help on how to install a starter relay. I have one and I need to know what wires go to what
Feb 28, 2009 at 3:20 PM
The starter relay does it have two small terminals label S and I or just an S terminal?
Feb 28, 2009 at 3:38 PM
SCIGUY
there are 7 wires and 4 terminals. 1 terminal labeled S and 1 labeled I. there are only 2 cords that would fit on those two.One of the cords is black and one is red.() Now the other 5 wire are as follows: one from the starter to the solenoid; one from the solenoid to the positive battery post; these two are thick cables. the other three are small wires: two say "Fusible Link" and the last one is blank. I hope thats enough information. I need to know where all of them go if you can.
Mar 1, 2009 at 12:42 AM
Do not connect the black and red wire -Hold ignition switch to start position the wire that has the power goes to the S terminal and the other for the ignition bypass circuit to apply full battery voltage to the coil.
the other three are small wires: two say "Fusible Link" and the last one is blank-This one here all goes to the battery side of the relay
Mar 1, 2009 at 1:41 PM
