need to know exactly what is needed to turn manual brakes into power brakes
thanks
Jun 7, 2008 at 7:42 PM
BLACKOP555
CERTIFIED EXPERT
try finding a ford f150 with basically the same set up, porportioning valve and so forth and the front metering valve and attatch it in place of the old one.
dont recommend this but it will work, be careful with steppign on the brakes.
Jun 7, 2008 at 9:31 PM
GTUTTLEPI
MEMBER
replace it with :
Prior Brake Booster
1973-1974 Ford F-100 Pickup
"PRIOR BRAKE BOOSTER, Power Section With Master Cylinder, Remanufactured, Core Charge Will Be Returned When We Receive Your Old Booster"
Fits: 1/2 Ton, All With 4 WD
this is around 167.00 bucks
I will need power brakes because I will be towing a 17" boat with it
thanks Garry
Jun 8, 2008 at 11:29 AM
BLACKOP555
CERTIFIED EXPERT
ive hauled about 1ton on a trailer with a 81 dodge. standard brakes, and it stopped just fine, go for a test drive with it and see how well it stops.
the booster just wont work, ou may need a longer pushrod.
