1967 Ford F150 valve stem seal replacement
1967 FORD F-150
I23MEDINA2009
Engine Mechanical problem
1967 Ford F150 V8 Two Wheel Drive Automatic
how do you install valve stem seals;the easy way.
Feb 20, 2009 at 3:46 PM
BLACKOP555
  • 10,386 POSTS
theres only one real way to put them on.
are the heads on the vehicle or off?
Feb 22, 2009 at 8:19 PM
I23MEDINA2009
the heads are on the truck.I heard there was a simplier way to do it. You use a spring compressor and do each one at a time.But you coil some rope down in each one so it doesnt fall through.You put the valve stem guides on one at a time.
Feb 23, 2009 at 12:08 AM
BLACKOP555
  • 10,386 POSTS
you can use rope, but ive always used compressed air. works alot better. just get the proper threaded adapter usually from a compression tester and just hook it up to a air compressor hose that way.
Feb 23, 2009 at 10:15 PM
