Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-100
Fuel System
Fuel Pump
Fuel Pressure
1986 Ford F-100 no fuel pumping to engine
1986 FORD F-100
217,000 MILES • V8 • 4WD • AUTOMATIC
MATASAC145
MEMBER
FOLLOW
i am getting power to my high pressure fuel pump but its not sending fuel to engine what could be the problem
Feb 28, 2010 at 5:52 PM
OBXAUTOMEDIC
CERTIFIED EXPERT
Ok, you are getting power to it. Does it run when key it turned to on position?
If High pressure pump is working then need to check low pressure pomp that is in the tank.
Feb 28, 2010 at 6:10 PM
MATASAC145
MEMBER
it only worked with a jumper wire
Feb 28, 2010 at 6:28 PM
OBXAUTOMEDIC
CERTIFIED EXPERT
Ok, in the engine compartment on the driver side firewall there is a Fuel Pump Cut-Off Relay. Check out link below for testing....
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Mar 1, 2010 at 8:23 PM
