Engine Performance problem
1967 Ford F-100 6 cyl Manual 400000 miles
I've got a 67 ford and I cleaned the gas tank all the lines and the carb really good. When you mash the gas pedal a few tomes to manually pump a little gas in the carb it starts up no problem the about a min later dies. As if it were running out of gas. I checked the carb while it was running and it shoots gas but after about a min stops? Do you think it's the fuel pump? Also I took the fuel pump off and the spring lifter on it when pushed up blows not sucks.
Oct 26, 2010 at 8:14 AM
