Stuck In Park
FORD EXPLORER
CASON30
I have a 2003 Ford Explorer, 55000 miles, 4cyl engine and recently I tried to change the brake light switch because the brake lights would stay on even when the truck was off. Once I disconnected the switch I reconnected it because the new one did not fit. Now, the truck will start but it won't go into gear and I have NO brake lights...Is this a computer problem?
Feb 5, 2007 at 11:18 AM
TAURUSWHEEL
  • 718 POSTS
Switch is probably bad, it controls the brake lights and unlocks the shifter, put a new switch in, you should be all set..
Feb 5, 2007 at 6:51 PM
