While driving, when I press down on gas, sometimes it doesn't respond.. It goes dead for a sec, then will catch and run fine for 5-15min at a time. Sometimes it seems to stall out more often on a hill. I'm leaning towards something in the fuel system, or a vacuum leak???
I had a used motor put in last year after I left water as coolant through the winter time. Ran fine for a while, now it hesitates and stalls out intermittently. I have no OBD codes. I have replaced EGR valve, IAC valve, Intake Manifold gaskets, TPS, MAF sensor, power steering pump. Alternator and battery are good.
1999 Ford Explorer Eddie Bauer SOHC 4.0L
Thanks for your time,
Chris
Chris
Aug 13, 2015 at 7:55 PM
