No Interior lights
FORD EXPLORER
COKEY43
I have 2001 Ford Explorer XLT, 79,000 miles, 4.0l engine, serviced 7/21/07 for 78,000 mile check.
Problem: no interior lights, will not come on, windows will not go down, hazards do not work, and fuses were checked and replaced. If hazard button is pushed, blinkers will no longer work. Also 4x2 and 4x4 light blinks off and on...off and on
Help
Jul 21, 2007 at 3:53 PM
CHEVY22
  • 1,375 POSTS
IM GONNA TRY AND TACKLE THIS ONE BUT NOT BEING RIGHT THERE THIS COULD GO ON 4 EVER,
FIRST PULL YOUR BATTERY CABLES OFF AND CLEAN THEM AND THE POSTS, SECOND CHECK ALL OF THE UNDERHOOD FUSES , DO YOU HAVE TURN SIGNALS??
AND THE WINDOWS ONLY WORK ONE WAY ?? IS THIS FROM THE DRIVERS DOOR SWITCH OR ALL SWITCHES ??
JIM
OH AND DO YOU HAVE A TEST LIGHT
Jul 22, 2007 at 7:46 AM
COKEY43
Battery cables are fine....3 week old die hard installed
turn signals work....harzards do not when button is pushed
windows do not work from any switch in truck
locks, radio, exterior lights all work
I have no test light
I checked all the colored fuses and they were fine
but don't know how to check (Black) relays?
Jul 22, 2007 at 10:39 AM
CHEVY22
  • 1,375 POSTS
THE RELAYS THAT ARE THE SAME YOU CAN SWAP OUT
Jul 22, 2007 at 11:55 AM
