Ignition switch replacement
FORD EXPLORER
4_NUBBS
I have a 1993 Explorer 4 wheel drive 4lt engine and I have lost my key. To replace the switch the directions tell me to turn the key to the run position. My problem is that I don't have the ignition key. Is there a way to remove it without the key?
Feb 17, 2007 at 4:11 PM
SERVICE WRITER
  • 9,123 POSTS
That's a problem!
Give the local lock smith a call or the dealer and have a key made. Not sure the secret on that one, but they will tell you what you need.
Feb 17, 2007 at 4:14 PM
4_NUBBS
[quote:5b210e6cff="Service Writer"]That's a problem!
Give the local lock smith a call or the dealer and have a key made. Not sure the secret on that one, but they will tell you what you need.[/quote:5b210e6cff]Thanks! I was afraid of that.
Feb 17, 2007 at 4:18 PM
SERVICE WRITER
  • 9,123 POSTS
I think it will be less painful than the switch?
Feb 17, 2007 at 4:24 PM
BIGG2003
you can go to a lock smith with the seriel number and they can cut a key or you can drill tumblers out through the key hole then punch out pin in old cylinder and remove. easiery to cut new key
Feb 17, 2007 at 9:23 PM
4_NUBBS
[quote:01ffbd5cbe="bigg2003"]you can go to a lock smith with the seriel number and they can cut a key or you can drill tumblers out through the key hole then punch out pin in old cylinder and remove. easiery to cut new key[/quote:01ffbd5cbe] Thanks, I will try the easier route as you two have suggested.
Feb 19, 2007 at 5:59 PM
