High beam lights constantly on
FORD EXPLORER
SHEWOLF30
Ford Explorer Sport Trac, 1996,246,000 k's, 6cylinder. Highbeam lights stay on and also the indicator on the dash stays on even when motor is off and keys removed. Have checked fuses and relays but with no luck. Have had to disconnect battery. :cry: :)
Mar 20, 2007 at 4:58 PM
SERVICE WRITER
  • 9,123 POSTS
The switch should be turning them off, probably the dimmer switch, which I believe is part of the multi-function switch.
Mar 20, 2007 at 8:16 PM
