Front end clunk
FORD EXPLORER
EXCENTRIFUGLE
  • 5 POSTS
2001 ford explorer awd 6 cyld 147,000 km. My question is. I have had a noise from the front left, and I figured drive shaft because I just replaced the right one about a month ago. I needed breaks so I did that now the noise in the front is real loud, If I back up then put it into drive it is fine until I press the breaks. This clunk only happens if I back up first then use the breaks in a forward motion. I did remove the wheel again to inspect my work and all is fine, however there does seem to be alot of play between the teeth on the spline when I hand turn the drive shaft back and forth. What do you think. Thanks for your help.
Nov 17, 2007 at 9:37 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d1e3302934="excentrifugle"]2001 ford explorer awd 6 cyld 147,000 km. My question is. I have had a noise from the front left, and I figured drive shaft because I just replaced the right one about a month ago. I needed breaks so I did that now the noise in the front is real loud, If I back up then put it into drive it is fine until I press the breaks. This clunk only happens if I back up first then use the breaks in a forward motion. I did remove the wheel again to inspect my work and all is fine, however there does seem to be alot of play between the teeth on the spline when I hand turn the drive shaft back and forth. What do you think. Thanks for your help.[/quote:d1e3302934]
when u did the brakes did u install back on the new pads the metal clip it was at the bottom of the old inner pads
Nov 17, 2007 at 6:21 PM
EXCENTRIFUGLE
  • 5 POSTS
[quote:655758c0bb="BMRFIXIT"][quote:655758c0bb="excentrifugle"]2001 ford explorer awd 6 cyld 147,000 km. My question is. I have had a noise from the front left, and I figured drive shaft because I just replaced the right one about a month ago. I needed breaks so I did that now the noise in the front is real loud, If I back up then put it into drive it is fine until I press the breaks. This clunk only happens if I back up first then use the breaks in a forward motion. I did remove the wheel again to inspect my work and all is fine, however there does seem to be alot of play between the teeth on the spline when I hand turn the drive shaft back and forth. What do you think. Thanks for your help.[/quote:655758c0bb]
when u did the brakes did u install back on the new pads the metal clip it was at the bottom of the old inner pads[/quote:655758c0bb] I am not sure what u mean,but when I did check everything yesterday all seemed good the pads can only go in one way,the clunk is hard enough and load enough to feel it through the floor. thanks for your input I will check everything again.
Nov 18, 2007 at 6:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:21e11fa25b="excentrifugle"][quote:21e11fa25b="BMRFIXIT"][quote:21e11fa25b="excentrifugle"]2001 ford explorer awd 6 cyld 147,000 km. My question is. I have had a noise from the front left, and I figured drive shaft because I just replaced the right one about a month ago. I needed breaks so I did that now the noise in the front is real loud, If I back up then put it into drive it is fine until I press the breaks. This clunk only happens if I back up first then use the breaks in a forward motion. I did remove the wheel again to inspect my work and all is fine, however there does seem to be alot of play between the teeth on the spline when I hand turn the drive shaft back and forth. What do you think. Thanks for your help.[/quote:21e11fa25b]
when u did the brakes did u install back on the new pads the metal clip it was at the bottom of the old inner pads[/quote:21e11fa25b] I am not sure what u mean,but when I did check everything yesterday all seemed good the pads can only go in one way,the clunk is hard enough and load enough to feel it through the floor. thanks for your input I will check everything again.[/quote:21e11fa25b]
Check radius arm bushing
It’s the bar that hold the front end to the frame
End of bar has bushing its almost under the seat outside the truck
Nov 18, 2007 at 8:24 AM
