FORD EXPLORER 4.0
FORD EXPLORER
JIM.D
1995 EXPLORER 130,000 MILES. FUEL INJECTORS ARE UNTOUCHED ORIGINALS. DUE TO GAS COSTS IS IT COST EFFECTIVE TO INSPECT AND CLEAN/OVERHAUL THE INJECTORS OR IS OPENING THEM UP ASKING FOR TROUBLE! CAR RUNS FINE.
May 12, 2006 at 2:28 PM
PEPPERMRJ
  • 1,158 POSTS
IMHO just run a tank of gas with fuel injector cleaner thru evry so often. I like Chevron Techron myself. There is a screen that can be cleaned on ford injectors and there are professional cleaning services available locally and online. I would do neither as long as the engine is running properly.
Fuel savings tips abound everywhere with the advent of $3.00 a gallon gas. Here are a few of my favorites.
Be sure of the proper operation of the thermostat. A stat that is stuck (open) will not allow the engine to reach operating temperature quickly if at all. The computer interprets this as a cold engine and provides a richer air fuel ratio.
Lighten the load. Auto manufacturers went to compact spare tires and plastic/composite materials to save weight and reach mandated fuel economy goals. Take the junk out of the trunk!
Put a quarter on the dash. Drive in a manner that will not cause the quarter to move. Fast start,stops, and turns all waste fuel.
Good luck. :)
May 12, 2006 at 8:21 PM
