'96 Explorer 5.0 V8 Auto
1996 FORD EXPLORER
GEORGERR
  • 9 POSTS
Anyone care to venture a guess as to where the EGR valve is located on this engine, and whether it's the valve or sensor that is setting a PO402 'excessive EGR flow fault code'???
Thanks
May 5, 2007 at 10:45 AM
MERLIN2021
  • 17,250 POSTS
If you look for the small flex tube running off the exhaust, the egr is at the end of it bolted to the throttle body...excessive flow could be a stuck valve or bad EGR solinoid.
May 6, 2007 at 7:35 AM
GEORGERR
  • 9 POSTS
Thanks Merlin. I found it. I'm new to these electronic everythilng engines and paranoid about making mistakes, so I proceed very cautiously.
May 6, 2007 at 9:59 AM
