Hi, I just got my armored explorer (XLT / 4doors / 4.6L) in Honduras, from out side looks the same, suspension has been changed and need to change for High Performance Brakes, because the weight of the car has increase in 680 Kg (1500 pounds) and is very difficult to stop the car and actual brakes get very hot.
Right now it stops faster a wagon of horses than this armored explorer.
Do yo recomend:
*Gas-port slotted cryogenically treated brake rotors Front & Rear(do you recommend to be drilled too).
*Performance Friction Carbon-Metallic, Carbon-Kevlar, Semi-Metallic Extended Wear, or Ceramic Brake Pads. Witch one gives a faster stop, more durable, low heat.
*Change the Calipers ? / Loaded or Unloaded?
Recommendations/parts/kits/brands??
I have a forward in FL.
Thank you,
Ricardo Gonzales
Honduras, Central America[img:4a187fe707]http://www.2carpros.com/forum/automotive_pictures/548945_explorer_xlt_2010_1.jpg[/img:4a187fe707]
Do yo recomend:
Thank you,
Ricardo Gonzales
Jul 11, 2010 at 1:37 PM
