ignition switch replacement instructions
2006 FORD EXPLORER
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
VLINIP
I was told that my Explorer has a bad ignition switch. It will not turn over, I have had the battery checked as well as the starter and all the fuses, they are all fine but because my door alarm, when the key is in the ignition, does not work, they tell me it is this switch. Are they correct and if so, where is it located?
Thank You for any help,
Lynette
Feb 28, 2010 at 3:12 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. I've attached picture steps below showing the location and replacement of the ignition switch on your vehicle. Hope this helps and thanks for using 2CarPros.
Jan 27, 2021 at 3:58 PM
