2005 Ford Explorer Removing the rear brake rotors
2005 FORD EXPLORER
KBRANDEL4314
Brakes problem
2005 Ford Explorer 6 cyl Four Wheel Drive Automatic
Last weekend, I tried to replace the rear brakes in our 2005 Ford Explorer. Everthing went fine until it came to removing the old rotors. I had the rotors loose but they would not come off due to the emergency brake or at least I think what was holding it on. I did not want to pound on it to hard for fear of breaking it. Any help would be neccessary!
Jan 12, 2009 at 8:07 PM
SERVICE WRITER
  • 9,123 POSTS
After the caliper is off, Whack the rotor with a hammer and spin it and whack it again. IT will work off. If anything let's go, it was probably ready to replace anyways.
Jan 12, 2009 at 8:20 PM
DAVE H
  • 13,384 POSTS
Removal
Remove the brake pads. For additional information, refer to BRAKE PADS.
NOTE:If the brake disc binds on the parking brake shoe and lining, remove the adjustment hole knockout panel or access plug and contract the parking brake shoe and lining.
NOTE:If the brake disc cannot be removed easily, apply rust penetrant on the brake disc-to-hub mating surfaces.
Remove the brake disc.
Jan 12, 2009 at 8:21 PM
SERVICE WRITER
  • 9,123 POSTS
Up here in snow and salt country, the adjusters aren't too cooperative too often. Almost all of them I do, I have to remove the adjuster and free it, clean it and lube it.
Jan 13, 2009 at 6:07 AM
CALEBHERNANDEZ
i have a 2005 ford explorer sport the passenger side rear brake caliper is loose the 2 bolts have been tighten the the pads are still loose not by much but when i brake it makes a grinding noise the rotor is in good condition please help with some advice
Aug 11, 2012 at 5:46 PM
