The fix is to get a driver who knows better than to seriously abuse an engine like that. What else do you think there is that needs to be diagnosed? Any engine can be expected to run hot after doing that, and even if it runs once it's cooled down, the temper will have been removed from some hardened parts, connecting rod bolts will have been stressed, and things like that.
To get an idea of the effect over-revving an engine has, a $100,000.00 NASCAR engine runs at around 8,000 rpm, and they hope it will hold up for 500 miles. A Chrysler 426 Hemi NHRA dragster engine develops over 3,000 horsepower and runs at 10,000 rpm, and it gets rebuilt after every race that lasts less than four seconds. Diesel engines typically run at very low speeds and in big trucks they last almost forever.
Your engine was designed to haul you around for 200,000 miles, but there's always a trade-off. To achieve the reliability we demand, we have to give up power, high speed, or some other characteristic. You can't run it outside the limits it was designed for for very long.
Aug 28, 2018 at 6:19 PM
(Merged)
